replace nic card in 470 Pro
I have a old 470 PRO that has the two port 1G ethernet expansion card. I got a two port 10G ethernet expansion card ( QXG-10G2SF-X710) that I want to replace it with. My question is when I replace it will the 10G card come up with the same config as the existing 1G? Thanks in advance.
its a new card, so it requires to be configured.
If the card is compatible with the NAS (check the compatibility list) connections that have not been prior configured, would be on DHCP for that NIC
