It’s not necessary to have a QNAP account (ID) to use a QNAP NAS online and get updates. ![]()
Hi, i would like to dm you my Mac adress for getting the cloud Key.
I have the same issue basicly.
I cannot acces my nas interface anymore because my password is not able to reset.
I tried the reset pin for 3 seconds untill it beeps. It goes to another IP adress in my network but the old login still works somehow. However, then the issue is again that i cant get in without my 2fa code.
Any advise on this? I created this account to be able to reply here so its not linked to my qnap interface either.
You can also open a ticket, not sure I understand what issue you are facing (2FA should be disabled after a reset)
Hi, I lost the admin password of my TS-233 , no stricker with the Cloud-Key , how I cand send you the macaddress via PM ? Thank You
You can also pop both of your disks out (while the NAS is off of course) and use Qfinder to read your cloudkey
https://www.qnap.com/en-us/how-to/faq/article/how-do-i-find-my-nas-device-cloud-key
After that coldswap (!!) your disks back into the NAS and …voila
Ok thank you! I’ll try
But if I send you the mac address , may i receive the cloud key, the Qnap is not physically available at the moment.
I have adjusted your permissions, you should be able to send me a PM now.
