Snapshots will not erase
Is there some way to reduce snapshot use?
I try delete all my snapshot and nothing appends, I know that it´s no real space allocated and I don´t know how restart this or Try to do that it snapshot use have a lower space.
Thaks for help
Please make sure you switch your UI to English before posting screenshots in an English forum!
First, this latest post should maybe be in a new thread.
So a few questions:
1.) Are you using a thick or thin volume?
2.) Do you have guaranteed snapshot space?
If you have guaranteed snapshot space, you can try reducing the amount of space that is guaranteed for snapshots.
Second, if you have a thin volume, it will gradually expand as needed. You don’t need to worry about it. And even if your snapshot space is larger than your guaranteed space, the snapshots will be deleted if the main storage volume needs to grow.
Does this help?
done
THIN
5%
I think that I can´t reduce more
I understand that I don´t be worried about this warning Threshold Reached
Thanx
So you can set guaranteed snapshot space to 0. Snapshots will still be created but there’s not a guaranteed space for them.
You can also go in and manually delete snapshots. You can also set up snapshots so that they get deleted if space is needed. Then you don’t have to worry about it.
Why didn’t I get more free space after deleting snapshots? | QNAP
