System error 53 when attempting to connect via SMB
Updating an old TS-509 Pro V 4.2.6 with new disks (it’s been working with smaller disks for years). Backed it all up and installed new disks, it reverted back to factory settings. Updated all settings and configured everything, but now can not see shares via Net View command (Win10 cmd window). I also have a working TS-869 Pro that’s working just fine (can see those shares via Net View so I know my OS is working). I have set Workgroup to the proper name. Any other suggestions?
See if enabling smb 2 or 3 is possible on this very old NAS
Thank you for the input. I have tried that with the results:
[~] # smb2enable
“/usr/local/samba/sbin/smbd” … not found.
So it appears it’s not a recognized command.
Bill
Also tried SMB 3:
[~] # smb2enable
[~] # smb3enable
For reference, I’m using one of my oldest NAS:
[~] # head -n6 /etc/config/uLinux.conf
[System]
Model = TS-559
Internal Model = TS-559
Server comment =
Version = 4.2.6
Build Number = 20240618
What is your current max protocol?
[~] # smb2status
smbd (samba daemon) Version 4.0.25
smbd (samba daemon) is running.
max protocol SMB 3 enabled.
If that command fails, run this:
grep protocol /etc/config/smb.conf
Also, check the samba binaries are present:
[~] # ll /usr/local/samba/sbin
drwxr-xr-x    2 admin    administ      4.0k Jun 18  2024 ./
drwxr-xr-x    8 admin    administ      4.0k Jun 18  2024 ../
-rwxr-xr-x    1 admin    administ    229.1k Jun 18  2024 nmbd*
-rwxr-xr-x    1 admin    administ     60.3k Jun 18  2024 samba*
-rwxr-xr-x    1 admin    administ     16.8k Jun 18  2024 samba_dnsupdate*
-rwxr-xr-x    1 admin    administ     94.8k Jun 18  2024 samba_kcc*
-rwxr-xr-x    1 admin    administ      7.9k Jun 18  2024 samba_spnupdate*
-rwxr-xr-x    1 admin    administ     17.9k Jun 18  2024 samba_upgradedns*
-rwxr-xr-x    1 admin    administ     59.3k Jun 18  2024 smbd*
-rwxr-xr-x    1 admin    administ    990.4k Jun 18  2024 winbindd*
If-not, suggest reinstalling QTS 4.2.6
Thanks for the tips. It looks like I’m missing some things. Here are results from the commands you suggested:
[System]
Model = TS-509
Internal Model = TS-509
Server comment = NAS Server 2
Version = 4.2.6
ls: /usr/local/samba/sbin: No such file or directory
I’m not sure how I would go about re-installing QTS 4.2.6. Is that spelled out somewhere?
Bill
I found the procedure to update the s/w. Working on that now. It’s loading. . .
Update has completed. It took a while to reboot, as expected. One of the messages that popped up after I logged back into the GUI was that SMB was updated. I then tried a Net View command and, Viola, I can now see my shares.
Thank you for all the help. The last time I played with *ix commands was 25-30 years ago on IBM AIX.
Now, back to the slog of restoring all of my files. Good day to all.
Bill
Thanks for your feedback! If you have any questions later on, please feel free to contact us anytime.
