I have a TR004 and I want to use the HBS 3 Hybrid Backup Sync
mine is not listed to download the software…
what do I do?
What do you mean “to download the software”?
HBS is to install on a NAS, not on the expansion unit or DAS
Hi, could you please tell us about your use case and main objective?
Also, just to confirm, are you using only the TR-004 , or do you have a NAS unit as well? Thanks!
