Model: QNAP TS-231P, QTS 5.2.10.3577, 1 GB RAM.
Setup: 2 x 2 TB in RAID 1 (thick volume, ~1 TB of data), replacing both with 2 x 4 TB (WD40EFZZ).
What happened:
- First attempt (replace disks one by one) failed. Later diagnostics showed the system partitions (md9/md13) had only one member (HDD 1), and the other disk had a read error.
- Second attempt: I replaced HDD 2 with a new 4 TB. The rebuild started, but after ~11 minutes the log showed on HDD 1 (the only remaining disk): “Read I/O error, UNRECOVERED READ ERROR / Medium error”, then “Skipped rebuilding RAID group 1”.
Current state:
- Pool and volume “Degraded”, running only on the old HDD 1 (SMART warning).
- The new 4 TB shows “Good” and appears in the RAID group, but “Rebuild RAID group” shows “Available disks: 0/2”, so I can’t start the rebuild again.
- BBM shows “No” and I can’t find any option to enable it.
- Data is backed up to Dropbox via HBS (real-time sync), and the old HDD 2 is kept untouched.
Questions:
- Is there a safe way to resume the resync or to make QTS skip/mark the unreadable sector instead of aborting?
- How can I make the new 4 TB appear as a free disk again so I can retry the rebuild, without losing the array?
- If not, is my plan reasonable? Copy all data to an external USB drive (file-level, which should only fail on affected files), then install both 4 TB disks fresh, create a new RAID 1, restore the config .bin, and restore the data.
Has anyone seen this with a failing source disk? Thanks!
