TS-453A and Seagate IronWolf ST4000VN006 Compatibility
Hello everyone,
I have a question regarding drive compatibility.
Is the Seagate IronWolf 4TB (ST4000VN006) compatible with the QNAP TS-453A?
I couldn’t find this drive model in the official QNAP compatibility list for the TS-453A, so I’m wondering if anyone is using it successfully or has any experience with it.
Has anyone tested this combination? Does it work without any issues?
Thank you in advance for your help!
Drive should work fine, QNAP does not test disks for old NAS models anymore
--Englische Übersetzung hinzugefügt von Dolbyman–
Ich habe nur das Vorgängermodell ST40000VN008, aber es funktioniert einwandfrei, daher würde ich erwarten, dass der Nachfolger genauso zuverlässig läuft.
@UdoA I fixed the wrong language for you, please make sure you post in the right one
If you run into any issues while using it, feel free to let us know and we’ll be happy to assist you. Thanks!
Thank you all. I will order the disk, connect it, and keep you informed.
