I bought it used on Ebay, I bought a power plug for it. It doesn’t turn on, however, I do have a both solid orange & yellow ethernet lights on the back. Also as I pull the plug out, the fan momentarily powers on.
Why was it supplied without a power brick? Was it maybe already busted (just not sold as it)
I bought it “untested”, so I was hoping I might get lucky. I just bought a power brick for it yesterday, with the same outcome. This is the plug I bought.
If a power adapter with the wrong polarity was used…you can blow the fuse on the board (best case)
Check if the fuse is blown
