After a PSU malfunction it appears that the power button stopped working. With the replacement PSU installed I can force the system to start the boot sequence by grounding the green “Power-on” pin on the 24-pin motherboard connector.
Does anyone have a repair guide that can help in disassembling the cover where the button in located? (Lower left corner of the front)
Any suggestions as to the best way forward? I’d assume checking the button and connection in the hope that replacing the button fixes the problem is first priority. And if the problem appears to be on the mother board instead of the button - the fix is to install a switch that can be used to force the Power-on cable pin permanently?
