I’m running two QNAP TS-h1277AXU-RP NAS units, both on QuTS hero h6.0.2.3591. Over the last few days, one of the units has started rebooting unexpectedly. After each reboot, the system log records the following message:
[Power] The system was not shutdown properly last time.
What’s strange is that my other NAS experienced the same behavior starting on 6/24/26. It would randomly reboot about once a week, but the issue eventually stopped on 8/2/26.
To rule out potential hardware problems, I’ve run S.M.A.R.T. tests on all drives and used memtester to check for possible memory issues. All tests completed without reporting any errors.
I’ve also gone through the system logs and activity around the times of the reboots to see if scheduled tasks, file transfers, or running services could be contributing to the problem. So far, I haven’t found anything that would explain the unexpected shutdowns.
The timing makes me suspect this could be related to the QuTS hero h6.0 firmware branch, as the issue appears to have started after upgrading to the initial h6.0.0.3500 release.
Has anyone else encountered random reboots on QNAP systems after upgrading to QuTS hero h6.0? Are there any known firmware bugs that could cause this behavior, or any additional troubleshooting steps you would recommend?
I’d appreciate any insights or suggestions. Thanks in advance!
I did do a memtest on my previous NAS following the instructions from support, and everything did come back good. I have not done one on the current QNAP that is having trouble, but what is strange to me is that this QNAP has been running for the last two years with its current ram with no issues. I might plan to do the memtest during a maintenance window this weekend, but I am going to guess everything is going to come back good.
Major firmware updates (like QTS 6 in this case) are notorious for tripping up ‘unsupported’ memory configs. Years ago we had the same thing and in most cases it was the memory.
QNAP support will also advise to revert to the stock RAM and investigate (sad for those that got rid of the original RAM)
Yeah, it’s hard for us because the stock ram was only 32 gb’s I believe. We have multiple VM’s running on this NAS that use more than the 32 gb’s . When looking up RAM to purchase that would replace the current ram (currently 128 gb on this QNAP) it was about $1800 . I am working with support right now and they have escalated the issue to their engineers so hopefully they can find a fix/solution soon.
