Upgrade of the UPS Management Subsystem to NUT >= 2.8.1
I would like to ask you to consider upgrading NUT, which is used as the backend for the UPS management tools, to version 2.8.1 or later.
Such an update would provide native support in QTS for many additional UPS models that are currently unsupported. Expanding compatibility in this way would significantly improve the user experience and increase customer satisfaction with their devices.
Thank you for considering this enhancement.
Thanks for the suggestion! I’ll forward it to our internal team for evaluation. Could you also let us know which UPS brand and model you are hoping to use? Thanks!
Thank you for your response.
I am particularly interested in uninterruptible power supplies (UPSs) from EVER.
My model is the EVER ECO Pro 700 AVR CDS.
According to the NUT project database, it is supported by the usbhid-ups driver:
https://networkupstools.org/stable-hcl.html?manufacturer=EVER&connection=USB&model=ECO%20Pro%20AVR%20CDS%20series
I would also like to see NUT updated. I maintain several QNap NAS, all running QTS 5.2.10. I just checked one NAS via SSH and found NUT version 2.7.4 installed. I’m interested in GoldenMate’s Pro UPS units which run NUT 2.8.5.
TBH the NUT Server/Client needs to be a full package and not a hacked up version.
I had asked for tis over here before now.
