I updated the QTS firmware on my TS-264 to QTS 5.2.9.3499. After that, my virtual machine in Virtualization Station was no longer available. I then tried to import the machine. However, in the directory of the virtual machine, there is only an img file, which can’t be imported.
After that, I created a new VM and attached the img file as a hard disk. But the VM won’t start.
What can I do to get the virtual machine working again?
Kind regards
Moved to the German subforum, please pay attention to the language!
I’ve never had a problem like this with any QTS update before.
Which version of VS do you have installed?
My NAS devices are running VS version 4.1.1.130.
Post a screenshot of your “newly” created VM.
Are the startup settings the same as well?
Especially the “UEFI” or “Legacy BIOS” setting has to be correct.
In the future, it would be a good idea to make a backup of the VM.
For this situation, we may need to obtain your logs and further review your case. Please open a support ticket so our support team can assist you further. Thank you!
(Translated by AI)
