Why is my QNAP NFSv4 mount read-only despite having rw enabled?
My QNAP NAS is mounted using NFSv4 with read-write (“rw”) permissions, but I get a “Read-only file system” error when trying to create a directory.
How can I fix this? Also, is there a good CLI-focused guide explaining how Linux clients interact with QNAP NAS devices over NFS
Are your NFS access permissions correctly set for that share in QTS? Can you post a screenshot of the current settings from the QTS Control Panel? Include the screen detailing IP addresses permitted access to the share.
You may refer to the FAQ below, which covers both the NFS settings on the NAS and how to mount the shared folder from UNIX/Linux clients. If you have any questions, feel free to bring them up for discussion. Thanks!
How to access files on NAS via NFS from UNIX/Linux clients? | QNAP
