I have a TS-873A with firmware QTS 5.2.6.3195.
I have a storage pool made by 8 disks WDC model WD80EFZX-68UW8N0, the pool is 50TB.
The space is occupied by snapshots for a total of 16TB even if there are no snapshots visible from QTS.
The issue is very similar to Zero snapshots consume 4TB of storage
follow the recommendation from the quoted issue: open a support case. Apparently, only QNAP can solve this. At least they did this for me. Good luck!
Best regards,
Frank.
Hi @SNB ,
Thank you for your report.
In this situation, we suggest creating a support ticket so that our technical team can analyze your system logs and assist in releasing the occupied storage.
You can create a support ticket through any of the following methods:
Click “Create Support Ticket” at the bottom of the forum page.
Open the Help Center app on your NAS to submit a ticket directly.
Visit the QNAP Service Portal at https://service.qnap.com/ to create a new ticket.
Our support team will review your case and provide further assistance.
Best regards,
QNAP Team
