Some time ago, either here on the forum or in a help ticket, I asked about why SmartShare downloads were so slow. I was told my a QNAP employee that everything with the MyQNAPCloud access had to go through their servers in Taiwan. There was not global CDN for this.
The only exception is the QNAPCloud storage spaces where you can pick where you want your server…
Thanks @HanzSung - so am I correct to assume then that not everything goes through Taiwan like I was told? That would be great. However, the bandwidth limits/speeds are really poor. I mean it is like 5 Mb/s. It’s been a while since I tried a large file download, but I know that a year or two ago, I was trying to share a video that I had shot and edited for a client and it took them forever to download it. It’s really a shame if modern speeds are not available on SmartShare links.
For the bandwidth we can open another discussion and ask other related team to involve.
But I tried to use QVR Client App + myQNAPcloud relay I can view about 8 cells at same time without noticeable connection drop. So, it should be lifted from 5Mbps to some higher value, but I have not performed a stress test of our infra.
Here is more feedback with installed new mobile app @haru0 sent me today.
Connection to NAS (via relay like first time also) took less time, cca 8-10 seconds via previously 30 seconds (but that might be to the relay speed/connected users number at different parts of day so can’t really say much)
Connecting to cameras on main dashboard screen took 3-5 seconds so that seems to be faster now.
Going into playback is another 4-5 seconds and when i find “event” dragging the timeline still has dropouts but definitely seems more smooth now than with older version. As for playback (i use it with sound) it’s still choppy, like plays 2-3seconds then stalls play again for few and then go back to connecting or stall… So not sure is that much or any better than before.
But I think @NA9D might be right here that relay is very slow and that chops it totally to unusable. I say that because @haru0 sent me link to new app through his myQnapCloud and downloading 200mb file was going for 18-20 minutes :/. It was downloading at snail pace of 100-150kbp/s.
So if myQnapCloud uses same relay services (does it?) as QVR pro/Surveillance is then it’s no wonder why is it so sluggish/slow playback.
Hope that helps with feedback to DEV team, thanks.
After 2 weeks of using this APP on my NAS na Phone i have more feedback/questions.
I use 2 x Reolink RLC-823A 4K (H256) cameras (supported in QVR Surveillance) and I use them as Event/Motion detection cameras so it’s not recording all the time but records on Events. I’ve set Evnet rules for both cameras same and that works fine/records on motion detection.
Only thing that is constantly wrong is Recording File TIME on HDD vs actual recording time (Time stamp on actual video) when event happened.
All my Events recorded are 30-60 seconds long (like car pases in front of my driveway or person walks etc. etc).. so no long sesions to make discrepancy between when it started and ended recording.
But on my NAS file date/time saved (in Events folder) is always 15-17 minutes LATER than actual video happened (visible by comparing Time stamp/counter on top of video and actual time vs record saved tiem in folder).
Time on Cameras and NAS are synced, they both are correctly set and show same time (+1 Time zone) but it seems that NAS saves files cca 15+ minutes later than when Event actually happened ? How that can be ?
We’ll it’s hard to know does it capure everything because time offset is 15-17minutes so even if I now go outside and wave at camera I won’t know did it worked untill that time passes and i actually get file saved in “event” folder so it’s very weird to test it :).
I do see plenty of files/events getting saved and it seems that it’s working but that time shift/file cration date is weird.
See here.
I just made fresh check as of this morning and Event happened at 8:04 AM (recording lasted 30 seconds) and yet my file got saved in Event folder at 8:23AM.
So shift in time for this one is now 19 minutes whcih makes it problematic to seek for some files manually if you know it supposed to happen in certain time and I start opening files to find it but i need to open 10-15 files to find “right one” :(.
If you need notification, the client will give you real time notification, and if you need a proper time for export, client shall give you the right time.
from your screenshot, the name of 20261102_“080421-080451”_ gives a proper time of the event.
and here is how actually the event recording do:
if you are not enable normal recording, it still recording the file and keep it on your disk for a small period.
in case no event happens, drop/auto delete the temporary file from the disk.
else, crop the needed part from the temporary file and move it to event recording folder.
This is why the event recording file comes bit later in about 10-20 minute in worst case, when the event is crossing twos temporary file.
by the way, in case the NAS is normally/unexpectedly shutdown, the temporary will be processed based on the same rule when QVR Surveillance is back online.
Thank you for detail explanation how it works, It makes sense somewhat (still not user firendly but at least now I knwo what is it doing).
What i wonder now is there a way to “shorten” that delay/mismatch time between actual Event time and saved file time ?
My pre-recording of Events is set 10 seconds before and 10 seconds after event so in this upper case total lenght of recrded file was 30 seconds which makes it like 10sec pre-record, 10sec actual event and 10 sec post-recording.
use the sample above, your event happens at the “point” of 08:04:31. So the pre-10 seconds are kept from the temporary recordings - begin from 080421 and you can know it from the filename.
at this point, we do not know when the event will end.
after a while, the event actually not triggering anymore at 08:04:41. And your setting will keep extra 10 seconds. So it ends at 080451. The duration is nailed.
Now QVR Surveillance will crop the video from temp file from 080421-080451 before dropping / delete the pre-recorded file. And create a new mp4 in your event folder at 08:23.
In case we want to shorten the creation time difference, the possible way is to reduce the segment of temporary recording file. However, any troubles for you to process file name, instead of file creation time?
Yes that is what I’d liek to adjust if there is a way ? Is there settings to tell QNAP how long it should record TEMP file before dissecting it to Event times/iel save ? Is the default maybe 30 minutes or so whcih cul dthen explain why in last case i had 19 min shift…
It’s not so much big problem or that i can’t get understand how it works now when you explained it (Thanks for your time), it is just counter intuitive to my other systems (Synology on 3 other NAS devices) which I use also in company to my new QNAP NAS.
Sometime I save recordings to separate Volume/folders to keep them beyond Expire date (I use 90 days rotation) so I save some files manually (copy them) to folder when i want to keep those events for years/forever and when i do it this way any sorting by Date my QNAP files aren’t actually sorted by date/time when mixed along my Synology files so order of recordings get mixed up eventually since i could have Event that happened in 8:30AM but got saved file data at 8:50AM and is should be sorted by date before all files from 8:31-8:49 but it isn’t since file save date is “shifted” to 8:50…
Hope you understan my “problem” now better :).
It’s just attention to details/user friendliness more than problem with saving files.
For supporting cameras with multi-stream in QVR Surveillance, it will be included in 3.1.0
and the version is already in our Smoke test so release ETA shall within next week.
(Recently most of our QA team is working on CVE issues so it took bit longer)
